Sleepr DSM
- 83
- Oct 15, 2002
How many DSMer's run over 25 pounds of boost? I know track cars run 30 psi+. What is your limit? What do you run on the street usually? What do you race at?
Originally posted by mclaren55
I run 23#'s on 94 octane.
Between 33-36#'s on C16.
Originally posted by 2-0turbo
Do you ever have any problems with head gaskets? Which one you using? O'ringed? I am planning on having my car on the road in the next 2-3 weeks with a turbo that has the capability of putting out the above described boost levels. I am on stock head bolts right now--I have ARP's on the shelf.
No problems with headgaskets thus far. I use a stock Mitsu 3 layer HG. Yes its O'ringed. I also have ARP head studs on the vehicle.
I think I'll limit myself to 25 psi (race gas) until I do some motor work. I don't know if I'll O'ring or not. We'll see what the beast does when I get it running.
so much tuning to do - on my first tuning run my EGT's peaked out at 1270, of course that was only 10.5psi...putting my boost controller on today
Originally posted by marshall
it's about time you're getting that turbo on, you've only had it for what 9 months or something? i got my T3/T4 on last weekendso much tuning to do - on my first tuning run my EGT's peaked out at 1270, of course that was only 10.5psi...putting my boost controller on today
marshall
It is getting there. I have too many projects in my life now. Believe it or not, the Talon is not costing me money every month like some of my other projects, so it doesn't get the priority.Originally posted by candela
I like the wire locks on the manny>turbine... Were you in the service?
I knew it... I used to work on ch-46 helo's and ofcourse being in the military as a helo mechanic you learn to safety wire everything =)
