NGK plugs
same plug. I had the same problem when I got them from Advance Auto Parts. They are the same part though, so no need to worry. The only difference is that the gap may possibly be different. Just check before installing them.
Supposedly the R is a resistor type and the other is not..... don't know if they are actually the same or not. If you use the BP7ES and end up having RFI problems, try the BPR7ES, but you should be ok.
