1gTURD
- 132
- Nov 20, 2002
Somerdale,
New Jersey
after having no idea why #2 had no compression, and an oil soaked engine... I pulled my head off to find a melted oval shaped piston. It is rather funny lookin!
anyways... I am buildin up a 1g awd and plan on finishing the engine for that rather than waiste $ on my fwd. The question I am asking is what would be a good idea as far as pistons go for this thing?? Im just lookin for a cheap/ easy fix but while im at it, maybe put some "ok" pistons in there so i can run more boost a bit more safely. I wanna keep the stock rods however. I dont have a whole lot of $ to spend. i was thinkin maybe a copper head gasket (or is stock fine) and some better than stock pistons to pop in there but... I do have to hone the cyl because the top (on the exhaust side) is a tad bit roughed up but I think that i can just extrude it and be ok. Again... just lookin for what I should do for a cheap easy fix and maybe pick up some ponies in the process (im porting the exhaust mani, intake mani, and the head while i have them out) i plan on just doin about 16-18 psi
the "mods" on this car are as follows incase it helps
Free maf sensor mods
greddy profec b
rewired stock pump
small 16g
550cc injectors
air filter
upper ic pipe
2. inch dp
stock exhaust
act 2100
thats about it off teh top of my head
anyways... I am buildin up a 1g awd and plan on finishing the engine for that rather than waiste $ on my fwd. The question I am asking is what would be a good idea as far as pistons go for this thing?? Im just lookin for a cheap/ easy fix but while im at it, maybe put some "ok" pistons in there so i can run more boost a bit more safely. I wanna keep the stock rods however. I dont have a whole lot of $ to spend. i was thinkin maybe a copper head gasket (or is stock fine) and some better than stock pistons to pop in there but... I do have to hone the cyl because the top (on the exhaust side) is a tad bit roughed up but I think that i can just extrude it and be ok. Again... just lookin for what I should do for a cheap easy fix and maybe pick up some ponies in the process (im porting the exhaust mani, intake mani, and the head while i have them out) i plan on just doin about 16-18 psithe "mods" on this car are as follows incase it helps
greddy profec b
rewired stock pump
small 16g
550cc injectors
air filter
upper ic pipe
2. inch dp
stock exhaust
act 2100
. but yeah i think i will use a stock head gasket seeing is that the old one didnt "burst" even if the piston did!! go figure
. I know not to port the manifolds without porting the head too. why port the manifold and not the head? the air flow will run into the head where it isnt "ported. besides im just talkin about a gasket match port and smooth out the casting bumps... nothing drastic. Ive ported a couple honda heads and manifolds getting ganes from 3 hp to 9 hp to the wheels just from doin a gasket match and nice finished surface. However, i checked the exhaust valves and they leak a bit. not a good seat... this is from heat and not a whole lot of back pressure from the exhaust i had. so in go a row of exhaust valves. im just gonna keep the dp and put a 2.5 test pipe in there with a "fake cat" slid ontop of the test pipe. that should free it up a bit. Im just not lookin to shell out another 300-400 dollars for a few horses (a few being 6 hp or 16 hp. To me its just another 400 i could have spent towards the aem ems or greddy e manage, or beer or somethin.
