Login
Go Back   DSMtuners > DSM Forums > DSM Tech > Bolt-on Tech
Bolt-on Tech 4G63 intake, exhaust, intake manifold, ignition, fuel system, cooling, etc.
Reply
LinkBack Thread Tools
Old 04-16-2009, 08:34 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
talontsiboy24's Avatar
Tech Posts: 279
Photos: 13
Classifieds Rating: 0
Reputation: talontsiboy24 is an unknown
Question Is .026 a good gap?
my buddy who is a tuner and tech did a tune up on my 97 gsx and i told him to gap the plugs at .028 but he said .026 is better is that true? and yes i used bpr7es.
these are my mods:
Chrome Forced Performance Green Turbo w/external dump tube
Black 3.5" Dejon intake pipe to K&N FIPK
Might have cams not sure
Walbro 255 fuelpump
Greddy Denso 660 injectors
Arp HeadStuds
Taylor Sport Compact Series 8mm Ignition Wires
Tial External waste gate
Custom 2g Ported manifold by AMS
Greddy oil catch can
Greddy type S BOV Recirculated
GReddy XTRA LARGE Intercooler Kit Type 24V
Greddy IC pipes
Greddy sport radiator hose kit
Polyurethane motor mounts
Braided stainless steel oil lines
Electronics:
Greddy profec b boost controller
Greddy Boost Gauge & Greddy Ext Temp Gauage
HKS Turbo Timer
Jumptronix air/fuel meter
Apexi S-afc
Hahn 3" DownPipe~
Thermal 3" Exhaust with 5" tip
View photos of this member's car
Advertisement
To browse the forums without the advertisements above, Login/Register
Old 04-16-2009, 08:36 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
habitatguy187's Avatar
Tech Posts: 1,466
Photos: 10
Classifieds Rating: 10
Reputation: habitatguy187 is more helpful than not
.026 should be fine, if you have problems (which you probably won't), just re-gap them.
View photos of this member's car  View this member's Blog
Old 04-16-2009, 08:36 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Proven Member
ApexVIII's Avatar
Tech Posts: 593
Classifieds Rating: 3
Reputation: ApexVIII is an unknown
mine are gaped at .024, but i have methanol injection.
i use the BR7es's alot of peoplehave had better luck with them over the BPR7es
____________________________
Methanol Injected HX35 95 GSX
Visit ApexVIII's homepage!
Old 04-16-2009, 08:39 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
PIMking's Avatar
Car: 89 mustang 358
Tech Posts: 1,360
Reputation: PIMking is more helpful than not
It will help with the spark blow out. You will be okay!
91 tsi 60k on the clock.
Old 04-16-2009, 08:41 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Quote:
spark blow out? that doesnt sound good...
Old 04-16-2009, 08:42 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Moderator
snowborder714's Avatar
Tech Posts: 4,961
Photos: 10
Classifieds Rating: 30
How much boost are you running?
Brian
Old 04-16-2009, 08:45 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Quote:
well my turbo can handle 24psi easy...but i usually dont turn my boost controller on unless im gonna be racing so now its running stock boost which is like 14.5psi...my low is set at 15.5 and hi 18.5-19 depending on weather...
Old 04-16-2009, 08:52 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Moderator
Tech Posts: 4,961
Photos: 10
The 7's will suit you well. Either .028 or .026 will be fine. As PIMking said, the smaller gap will help prevent the spark from blowing out. And either BPR or BR will be fine.
Brian
Old 04-16-2009, 08:52 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Proven Member
TRBOBLU's Avatar
Tech Posts: 306
Classifieds Rating: 7
Reputation: TRBOBLU is pretty helpful and trustworthy
Quote:
Originally Posted by talontsiboy24 View Post
well my turbo can handle 24psi easy...but i usually dont turn my boost controller on unless im gonna be racing so now its running stock boost which is like 12psi with my low setting turned on i make about 18-18.5...
Should be fine at .026-.028 with 24psi on your setup. If you blow out the spark just gap them a little lower.
Old 04-16-2009, 08:59 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
thanks guys by the way i love your cars they look awesome...dsm 4 life!!!!!!!!!!1
Old 04-16-2009, 09:34 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
JayRolla's Avatar
Tech Posts: 4,647
Photos: 5
Classifieds Rating: 6
Reputation: JayRolla is extremely helpful and trustworthyJayRolla is extremely helpful and trustworthy
What I do on any dsm is start at .028 and I dont have a misfire I am good. If I do then I start too lower just a little. I have always been able to run .028 at 30psi with no issue. Others with larger turbos pushing 35+psi have gone as low as .018. It just depends on how much boost and cylinder pressure.
Jason~6bolt/4bolt E316G@32psi, ECMlinkv3, Corn Fed
Old 04-16-2009, 11:18 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
kp116's Avatar
Tech Posts: 98
Reputation: kp116 is an unknown
I say you should be fine as long as you don't have any lean running issues... Making the gap smaller will decrease ionization voltage need to jump the gap and increase spark Kv (burn time). Also the smaller the gap the harder it is to ignite a lean afr but I don't think you should have any problem with that.
Old 04-16-2009, 11:52 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
Tech Posts: 60
Reputation: turboboy4 is an unknown
Yea you should be fine at .026". high boost would be the only problems you run into and by the sounds of it the boost you are running wont be high enough to blow the spark out
Old 04-19-2009, 12:33 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Quote:
ok but how much boost can my engine handle i believe its stock? i just dont wanna go over 18psi and damage it...
Old 04-19-2009, 03:02 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #15 (permalink)
dmc Offline
New Member/Lurker
dmc's Avatar
Tech Posts: 27
Photos: 13
Reputation: dmc is an unknown
Well the bigger the turbo the more air it will produce at the same psi level. For a green I would not go over the 18-20psi you mentioned. You will make nice power at that level, but the best way to do it is to have a data logger or some kind of tuning program and tune it to the knock it is seeing ( and within the a/f ratio for the fuel you are using). You have 660's so knock should not be a big problem at 18-20.
Spark plugs with only BR and not BPR, are spark plugs with a non prutuded tip ( the ceramic part right by the tip) The higher the boost the more chance of catching detonation, the BR spark plug reduce the chance of detonation at high boost and high rpm. People with spark amplifires can open the gap bigger, it burns the fuel better creating more power. 0.26 shoud be just fine for your plugs, start there and see where you are at.
Old 04-19-2009, 03:07 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #16 (permalink)
dmc Offline
New Member/Lurker
dmc's Avatar
Tech Posts: 27
Photos: 13
Oh I forgot to mention, BR spark plugs do not last as long as BPR spark plugs! Hope I answers you questions.
Old 04-19-2009, 10:21 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #17 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Quote:
im sayin with my mods is 18.5psi ok to run with a stock 4g63 7-bolt? i mean how much boost can i run that will be safe for the engine?
Old 04-19-2009, 10:37 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #18 (permalink)
Proven Member
toofast82's Avatar
Tech Posts: 2,112
Photos: 4
Classifieds Rating: 5
Reputation: toofast82 is pretty helpful and trustworthy
It's all in the tune and setup. I would recommend a set of head studs if you plan on pushing your setup above 22psi. Stock 7bolts have handled 30psi+ and some pretty high power numbers.
18.5psi huh?, not 18, not 19?
Old 11-03-2009, 09:15 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #19 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Question Whats the best gap for a 2g gsx spark plugs?
Im running ngk bpr7es plugs,20lbs of boost,fp green turbo,etc...
my gap is at .026 now but i was thinkin to go with .020 i heard its best when running hi boost like that? at .026 i still have misfires..my car is not breakin up at full boost with my gap how it is now but people have said goin lower is better anyway?
Old 11-03-2009, 11:16 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #20 (permalink)
Proven Member
turboking15's Avatar
Tech Posts: 176
Reputation: turboking15 is an unknown
Search around, this has been covered before
Old 11-03-2009, 11:22 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #21 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Quote:
so say i gap them lower then .024 will that make my car harder to start?
Old 11-04-2009, 01:53 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #22 (permalink)
Proven Member
wont_luz's Avatar
Tech Posts: 77
Photos: 25
Reputation: wont_luz is an unknown
Looks like people have answered this for you before
Old 11-04-2009, 01:58 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #23 (permalink)
Proven Member
ApexVIII's Avatar
Tech Posts: 593
no lol it wont
Old 11-04-2009, 06:03 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #24 (permalink)
Proven Member
No_Skillz's Avatar
Tech Posts: 1,892
Photos: 18
Reputation: No_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening toNo_Skillz is an experienced, knowledgeable member worth listening to
No AFPR? Worrying about spark plug gap when you don't have an AFPR with a 255 pump is like worrying about a chipped nail when you have a sucking chest wound.
| M | i | k | e |
Old 11-04-2009, 08:27 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #25 (permalink)
Moderator
LandoAWD's Avatar
Tech Posts: 3,267
Photos: 17
Quote:
Originally Posted by wont_luz View Post
Right way...
Quote:
Wrong way...
Kris
1991 Talon TSi
Old 11-04-2009, 08:29 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #26 (permalink)
Proven Member
95blackGsTurbo's Avatar
Tech Posts: 2,870
Photos: 12
Reputation: 95blackGsTurbo is an experienced, knowledgeable member worth listening to95blackGsTurbo is an experienced, knowledgeable member worth listening to95blackGsTurbo is an experienced, knowledgeable member worth listening to95blackGsTurbo is an experienced, knowledgeable member worth listening to
If I were your I would consider dropping to a BPR8ES and running a .24" gap. For your mods it would benefit you more than dropping your gap even more. If it isn't breaking up I would look into why it is misfiring as well. Unless you are sure it's the spark plugs. And turboking15, apparently you can't read the rules either. It's number one on the before you reply rules above every reply box. Please don't create multiple threads pertaining to the same subject. Bring the old one back from the dead if you have to.
Adam Thilges
Old 11-04-2009, 08:36 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #27 (permalink)
Moderator
99gst_racer's Avatar
Tech Posts: 4,738
Photos: 58
Classifieds Rating: 31
Try tightening it just a little bit. Before I had an ignition box, I was running a .023 to get rid of the high boost misfires. Now that I have an ignition box and more boost, I run a .018 gap. I'm not sure how well a tight gap like that would do without an ignition amplifier though.
-Paul Volk-
'99 GSX
'91 TSI
Visit 99gst_racer's homepage!  View photos of this member's car
Old 11-04-2009, 11:05 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #28 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Quote:
Why u think that can be the cause of my misfires? cause at full boost it dont misfire or break up but im gappin the plugs down to .024 to see what happens just to be sure.
Old 11-04-2009, 11:07 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #29 (permalink)
Proven Member
Tech Posts: 2,870
Photos: 12
If you are overrunning the stock regulator then yes that can cause a misfire.
Adam Thilges
Old 11-04-2009, 11:12 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #30 (permalink)
Proven Member
Tech Posts: 279
Photos: 13
Quote:
yea im gonna add the afpr kit soon just gotta deal with it for now.
well i just put new plugs in and gapped them at .024 bpr7es so that shoud be fine right?
Last edited by talontsiboy24; 11-04-2009 at 05:14 PM. Reason: Auto-merged with previous post to prevent "bumping"
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
Plug Gap Blitzeclips 420A Turbo Conversion 8 07-28-2006 10:40 PM
best way to gap rings? Boostedexcel Newbie Forum 4 01-04-2006 12:05 PM
What gap?? Happy Newbie Forum 2 06-30-2003 08:22 AM
Gap Q GSX Zemus Bolt-on Tech 4 05-24-2003 08:35 AM
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Seat
by: Spdfreak
Update 4
by: Kevin TSI
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
» Recent Tech Threads
Title, Username, & Date
Holset Bolts loose?
by: fastfive0
anybody know where this wire goes?
by: kneipperk
Need help with TurboXS DSMBC
by: EclipseGst1992
1g maft install on 2g
by: hondaslayer1
should i buy 1g or 2g?
by: mcavalear
» Latest Gallery Photo
User slowjontsi
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 34.78%
8 Votes
18 Votes
7 Votes
Total Votes: 23
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
