.48 vs. .63 a/r lag and power
TheHater
35
Sep 18, 2002
I'm trying to convince 2 of my frieds to dump there .48a/r for a bigger .63.
Setup #1: 2g fwd
to4s 57 trim, .48 w/a stage 3 wheel
setup #2: 2g awd
to4e 50 trim, .48 w/a stage 3 wheel
Both have HKS cams 264/272(1) and 272/272(2), sfp mani's w/35mm tial dumping to the atm, fmic, inj,2g tb/intakes, unported 2g heads, etc.
Basicaly I need some more backup because both are afraid that it will be to "laggy".
#1 setup is fast, but nowhere near as fast as it should be.
#2 isnt running yet, but another local in a 1g awd w/a 7.8:1 jdm motor gets full spool ~4k w/the #2 setup, except .63 exhaust housing. So in realisticaly the #2 setup should spool up quicker because of the 8.5:1 compression.
I'm looking for personal trials, dyno's, et, mph to back me up. Also anyone w/experience using the PTE housings, and if they can be swapped for the garrett 4 bolt housings. Ive heard only good things about the PTE housings.
Thanks,
Mac M.
I switched from a .48 to a .63, and then to a .82 A/R on my 57trim to4e/stage III. The car spooled TOO fast with the .48, I don't need full boost by 3500rpm, how much time do I spend below 5000rpm at full throttle? Almost none. There was a BIG increase in power when I switched to a .63 A/R, and the lag was perfectly acceptable IMO. So I went even bigger with a .82 A/R, but it did make as much of a difference, and spool up time was still fine. I ran pretty much the same times with the .63 and the .82 (mid 11's off the bottle@120mph, low 11's on the bottle@126mph).
Where at in Phoneix you from hater? I live in N. Phoenix... Ive never seen you around unless Im mistakedn. Anyhow why does that dude have the t04S? Anyhow, jason is right Ive only been in 50trim/57 trim .63 cars before but that lag was ~3800 full spool and that really not bad for the increase in topend you get from switching...
Candela:
You know me, I have the silver 95 gst, I'm Mac. We ####ed around on 32nd street a while back and I've seen you at a few SWDSM meets. Did you get that motor in?
The 57trim is spyder's on the site, another local guy. The white spyder w/the bling bling 19" chrome rims, dvd player, etc.
About the to4s, it was put together by the POS shop MAX REV in tempe, who can suck a fatty. They are the worst shop when it comes to dsm's. The compressor housing would barely fit w/an SFP/agp mani made for more clearance for the garrett combos.
Jason's TSI:
what is your apprx spool w/the .63? Say a 3rd gear pull from low rpm?
I know that the .63 would be a nice gain to both, but they are both afraid of lag.
Originally posted by 90 EagleClaw
I have a .63 on my 90 Talon with a 50 trim compressor and the lag is horrible. I was told to go with a .48 housing. What compression are you running with the .63 to get it spooled that early? I am stock 7.8:1
I had full spool on my 50trim Stage III .63AR with 8.5:1 compression by 4000 with the car completely untuned.
8.5:1 and 4000 is still pretty laggy and might explain why mine is even worse at 7.8:1 comp. But I might have a combination of things wrong, I might also have the wrong cams in the car, im trying to figure that out now. Im going to try going with a .48 housing to see how much it helps though, since its easier then doing cams.
THANK YOU. I get sick of arguing with people that .48 housings are too small for a hybrid T3/T4 application. Boost onset is to violent and you end up with a smaller power curve that looks like a spike at the beginning and a dip at the top.
If you are running big cams, it's all the more important to use a nice free flowing housing so you don't choke the cams power potential up top.
FYI I gained *80* whp going from a .63 housing to a .82 housing with a 76 trim stage-III turbine wheel and a 50 trim T04E compressor in a .50 housing. Same boost, same dyno, same tune.
When the turbine chokes, it really doesn't matter how big of a compressor you have. Power gains will be minimal.
Remember this thread?
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=42241&perpage=25&pagenumber=1
How about you find out what's wrong with your car first before making a statement about what works and what doesn't? Just and idea. :)
Yes I remember the thread, obviously this is what Im trying to figure out. I have taken my car to 2 different DSM specialist shops, and we have checked EVERYTHING with the car. The last shop I was at, after checking everything over, we went out for a test drive. He said my car felt exactly like another DSM that was running a Hahn super20G, and when they switched the car to a 57trim T3/T4 with a .48 housing, it picked up a ton of power and spooled 2000 rpms sooner. So they suggested I try it out to run a .48 housing, they did say if I had higher then stock compression and aftermarket cams then the .63 would be better suited for that, but they think it is too big for a bone stock 1G motor. All I can do is try it and see, if that doesnt work, then I will try changing the cams to stock turbo cams because they said the only other reason they could see this happening is that I might have NT cams in the car. Too much overlap would cause the turbo to not spool up, and my car was a timing belt victim before it was mine, so who knows if the shop that fixed it bolted on a NT or Auto head? All i can do is try differnt parts, cause everything else with the engine and tuning is in line...
Jay,
Was that on cams designed for a turbo or N/A? It makes all the differance in the world. Can you post both dyno graphs?
Kevin
AGP Turbo
Wow you think thats laggy? I guess I just got used to it where anything before that seems like insta boost now. I also spend hardly anytime below 4000rpms anway :)
You can't tell just looking at them. If your car came from the factory with a turbo then they are turbo cams.
Kevin
AGP Turbo
Originally posted by Z1500
Jay,
Kevin
AGP Turbo
Good question. First off this was not on a 4G63, but a SR20DE BUT they are so similar in regard to displacement, VE and RPM range it's really splitting a fine hair.
Second, the cams were designed for a NA application BUT they were very turbo friendly. Not much overlap, decent duration, BIG lift, LOTS of area under the curve (Think of how a square cam lobe would benefit and you get the idea)
Third, I don't have the final 409whp pull on line anymore. I sold my old company and domain and havn't set all my files up on my new domain. Sorry.
Has anyone ever even really looked at the auto cams? Because when I put a auto engine in my car to replace my timing belt victim engine I felt a big increase in power, but this could be due to better compression or something. But there is always that change that the auto cams are different in a good way. Now I can spin all 4 tires into second gear with a stock fuel system and a small 16g at stock boost creaping up and a 2.5 inch exaust. Oh and the mani and o2 sensor housing are ported, man I cant even stay out of the boost I seriously cant drive my car normaly anymore it starts spooling and pulling I have to shift at like 2000 rpm's to stay out of boost but then is bogs out. But anyway I dont think there is a difference in auto or manual cams.
Drw
My compression is 9.0 to 1. What manifold are you using? If you are using a mitsu manifold with an adapter plate that would cause a lot of lag.
Why would that cause lag?
I have been going through a similar situation with my MR2T. I am trying to size my T3/T4. I do want nice spool, but the point made about never spending much time below 4k was well-taken. I downshift.
FWIW, I settled on an ITS Dual Ball Bearing T04E-50, with a .48 hot side and Stage 5 wheel (Stage 3 just isn't enough, kind of a compromise between 48 and 63s). If it sucks, I'll go to a 63, stage 5. :) Beauty of hybrid turbos.
What car do you have? There is no difference in 2G cams, but there is a difference in 1G manual vs. auto cams.
Also, I keep hearing that the 1G M/T cams are a little better than 2G cams, so I picked up a set ultra-cheap to try them out. Haven't put them in yet, though.
People that are so concerned with spool that they would choke off top end with a .48 housings don’t understand that they have a 122in motor 4 cylinder motor. If you want to have all sorts of low end buy a Mustang. They have TONS of torque. Or go 2.4L and choke that off with a tiny turbo. But I think you are really missing the point of a turbo 4 cylinder its all about helacious top end.
I’m sure I am making well over 400 wheel hp on pump gas with my current setup and I have a nice 4k power band about 4-8k. To me that’s more than acceptable. However when I drive my friend’s MUCH slower Mustang (110 traps) around the block and through the neighborhood it feels a lot faster at super low RPMs. His powerband is probably 2800-5300. A powerband like that isn’t going to happen in a DSM if you want to make serious power. You just have to accept that fact and move on.
I think this is good oversight advice. I just ordered a .63 housing for my 50 trim. I haven't even been able to make a pass with it yet because of the weather here but I can tell that it feels a little choked in the top end especially with my 264/272 cams. The spool up is so fast with the .48 that I know I can live with the .63. I was worried about lag when I bought it but I think I should have just got the .63 in the first place.
Has anybody done any tests on exhaust manifold pressure to compressor pressure ratio. I would not think it is that hard to do. You just need another boost gauge to monitor the exhaust pressure. I would be curious to see the ratio difference between the two housings.
That's a good tongue twister. It took me about 4 tries to get that one out of my mouth! :p
Mike 99GSX,
What is your current setup with the .48 spooling up at?
iron
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
