P8ntBalla
- 1,048
- 1
- Jun 4, 2002
ok, well i got my ported/clipped 16g and ported exhaust manifold on, and my boost creeps like a mother####er. there is no exhaust restriction behind the wastegate, and i have gone through all the vacuum hoses and intercooler pipes, and just about everything else i could think of. i even swapped my hallman mbc out for the kind that is milled out of a block of alluminum and it still does it. the turbo is brand new, so i dont think the wastegate could be bad.
me, as well as the people at my shop, are completely confused; that is why i have turned to the wisemen. can you think of anything else that i should look at or replace?
Make sure there are no weird restrictions in your setup like gaskets being way off or your wastegate not opening all the way... Id once over everything than maybe consider cranking it and/or porting out the w/g more
