Q about t3/t4 57 trim
ZSPTurbo
178
Oct 30, 2002
If it was running say.... 23 psi, when would it hit full boost? like, 4000 rpm? from a dead stop, like on a dyno run or something.
with what exhaust a/r and what stage compressor wheel. The typical combo would be .63 a/r and a stage 3 wheel and your looking at maybe 3750 rpm, not bad at all
what about with a big spearco fmic like the 2-216 core, will that affect spool times on the turbo at all? I was thinking about the same turbo but a 50 compressor not 57 but the same .63 a/r stage 3.
Any opinions on that? I dont wanna lose my quick spool of the t-25 anymore than I have to.
thats a very good turbo, and the spool will not be bad at all, itmight bother you for all of 58 hours and then you'll never want a smaller turbo again. trust me on this. Intercoolers do not add very muchlag at all.
it would hit full boost at 3750? really?
T3/T4, 57 trim stage 3 wheel, .63 A/R
For 23psi. Not even. Maybe 15psi@3750.
Swtiching to a 57trim turbo is not going to spool anything like the t-25. if you want that kind of spool may as well switch to some type of big28.
well then, for the setup that I said, when would it hit full boost?
I agree with L2R...
But I also contest that anyone whom is thinking of going garret 57trim to check out the flow rates/maps of that trim compared to a 50trim wheel (it is much more efficient)... although it is usually a little more expensive it is worth it IMO!
Originally posted by waterdeep
I agree with L2R...
oh, I have already decided to go with the 50 trim and .48, I was jut curious about this turbo.
I have been in a modded 2g gst with the stock motor with a 50trim, .63ar stage3 and it got 18psi @3800rpm
wow, I ran the equations on the compressor map, and this definatly isnt the turbo you want for 23 psi:
Originally posted by DSMJim
wow how did you do that to lay the line over the map? I wanna do that with a 50 on the same engine with a .63 vs. 43 exhaust a/r
well, its a couple things. its all in this one special equation though. IM me and Ill try to explain it. im me, zspturbo
gtg, Ill just plop the equasion down and explain it tomorrow.
Litres x 61(CID) x RPM x .5 x Volumetric Efficiency
------------------------------------------------- = Result x Pressure Ratio = CFM Flow x 0.0756 = Pounds of air per Minute ( Lb / Min )
1728
ok, that didnt come out good, copy and paste it in word or something.
its more like this:
divided by 1728
x desired pressure ratio
x.0728
equals lbs/min.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
