Turbine wheels
Bigwilly6754
129
2
May 28, 2002
I was just wondering whats the difference between a stage III and a stage V turbine wheel ????? thanx everyone!
More flow.
What exactly is the answer you are looking for? :confused:
That totally depends on what your goals are and what you want out of the turbo.
You can't make that determination based on "which is better".
You have to provide more information with your question.
The stage V will induce more lag. In other words it will take longer to spool up. Probably creating power above 3500 rpm's, but would create more power once it is spooled. If you are looking for the most streetable go with the smaller of the two. If its a track toy go big.
Flows more CFM but yes we need more info than unless that's all you want to know.
