gsx ftw
- 105
- 1
- Jan 5, 2008
510/408,
California
So I installed a Greddy UICP, Greddy Type RS BOV and then cleaned my K&N intake with the K&N recharge kit. All went well- cold started it and idle seemed normal, RPM's jumped a bit higher than normal and lingered above 1000+ RPM's more than usual, but I thought nothing of it.
I take it for a drive- I notice I'm getting some compressor surge so I stop at a gas station and soften the BOV. I then start driving again and then notice that my car is searching for idle. As I pop it out of gear and neutral/brake toward a stoplight, my RPM's stick up near 1500. After a complete stop, it takes a couple of seconds for it to drop to 1100. After that, it drops to 800 then it goes back to 1100. From 1100 to 800 back to 1100 takes about three seconds.
What could be wrong? I may have overoiled the the K&N filter a bit, but I let it sit and dry for about two hours while excess oil dripped off. Before I put it back on, I shook some excess off. I don't think it could be a boost leak- I hit 14 psi and it crawls into 17 because I don't have a cat and I guess my wastegate on the T25 isn't efficient enough.. I should keep off it- fuel system is stock.
About the car before today - P0505 every now and then, IAC malfunction, I'd say it would happen at least 2 times a day with about 5 short trips (under 30 minutes). It's weird though, because with the old EXTREMELY dirty filter and stock UICP, it didn't have any symptoms besides throwing the code. Also, with the 20 minute trip home after installing the parts, I didn't throw the code once. Stock boost level before today's install was 10-11 PSI and would drop to 8 by redline.
Any ideas guys?
Any ideas guys?
. but now i have a rebult ecu and it runs great
