turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
I pulled my old "255" in order to replace it with a newer 255HP because iot was falling off at around 6700 RPM at 24 psi on E85. Well i thought i'd cross the numbers from the one that came out and see what ir "really was" since i had picked it up 2nd hand from a GN that i was working on.
The numbers are GSS-307 which doens't fit any numbers found on RRE's site. I googled it and came up with some references to 255lph pumps but 190's were mentioned as well with no difinitive answer. So, does anyone know what this pump was rated factoory? I've searched and maybe i didn't put in the right words but i couldn't get an answer in my lookings.
Edit: Jsut found in this link below that it's another part number for an old 255 but its of the lower pressure variety.
Stealth 316 - Fuel Pump Upgrade Guide
