N1 on stock turbo... trouble?
StarCraftLover
188
Oct 2, 2002
stafford,
After I installed my N1 exhasut with the DP, I've kinda noticed a loss in power from 1K-4k, and then it picks up alot better. Is this normal?
I also have alot worse of traction issues in 1st gear...
Thanks for the help.
Marty
check your catback and dp, you might have a leak... you should notice a huge difference with dp and catback.. good luck.
Well I was wondering, does the fact that I have to large of piping for the little turbo hurt my performance in lower rpms?
Ive heard that 2.5 is better for the stock turbo...
true?
Your prolly laggin just a small bit in the low end because your 3" all the way back with stock turbo and stock boost. You should see quite a difference in the top end though. Get a K&N/Intake, boost guage and boost controller and you should be good to go. But also as meantioned, check for leaks as well.
