Wobble
- 726
- Jan 2, 2003
well first I put on an HRC wastegate actuator.. and my USUALLY rock solid hallman RX boost controller (the fancy one with the ceramic ball) stopped being as effective.. before HRC i would spike maby .5 psi @ 16 pounds... with the HRC.. spiking to 20..
then i swapped a 1g head and intake on.. now I have NO controll.. even with the controller set at its lowest i still push 18 psi in 2nd.. 19 in 3rd and about 20 in 4th.. it doesent creep to these numbers.. it just spikes past.. then settles on them..
should i put the stock actuator back on? whats the deal..
i know i should get an electronic boost controller (apexi avcr is next mod) but i is a po boy..
any ideas?
ps: all vac lines are connected correctly.
any ideas?
