Bad TPS?
GVTalon
469
2
Mar 8, 2002
New Fairfield, Connecticut
I've got idle surge. :( This happened after I pulled the intake mani to install a direct port nitrous system. I put everything back together and upgraded to a 1G TB. I had to move the emissions soleniods and extended the vacume hoses. I fired up the car and it idled high then after it warmed up it started surgeing. I just yanked all the emissions stuff and installed an EGR blockoff, I figured if I got rid of all the stuff I wouldn't have to search for vacume leaks. Well its all back together again, I fire it up and it does the same thing, idle high then surge after its warm. So is this an indicator of a Bad TPS?:confused:
Well after the car warms up, the idle begins to fluctuate up and down between 1,000 and 1,500 rpm...and doesn't stop. I understood this to be idle surge, I also understood this to be a common problem on DSM's. However whatever board I go to and post about this problem, no one knows about it.
I may possibly have a bad TPS. After I drive for a while the AFC starts to show throttle percentage even though my foot is not on the gas and the will of course rise until I've been driving for a while an it says about 3.5% throttle and idle is about 2000rpms. Very annoying.:mad:
Later,
