'90-'99 4g63 Cams?
BLITZ SPYDER
can the CAMS be inter-changed between a 1G and 2G? The reason i'm asking is because i'm doing a head swap on my 2G to a 1G head, if I use the 1G intake CAM I would have to modify the CAM a little to use the 2G CAS, but if I can use my 2G intake CAM, the CAS will bolt right up.
Yes except on a 97-99 the cam is drilled for the 97 cas.
so..what your saying is that I can use my 2G Intake Cam on the 1G head without any problems..right?
