snipe99999
- 301
- May 13, 2002
Anyone have a link for instructions and pics of a profec b install? I looked in the vfaq because i thought it was there but could not find them. Thanks, Ian
OK one more question there are 3 types of internal swing valves. Which one do I use? And what selectors should be on and off? Also what did you use to cap off the open ends.
You can tap both, but if you already have the fuel pressure line tap for a boost gauge, then tap the bov line because it a bad idea to tap two things on one source you know what im saying?According to the directions I am supposed run the line from the profec b to the fuel regulator and intake mani. Should I do this or should i tap the line going to the BOV? Or is there another place that I should tap?
Originally posted by Mistaspakles
So if it's not a good idea to tap into the FPR line, and tapping into the BOV makes it flutter, where are you supposed to tap it? Also, do you have to cap off the WG solinoid?
