focusedrage
- 1,053
- Aug 3, 2002
Laytonsville,
Maryland
hear is what happens, i can slam on the peddel and the boost is up at 14/15 psi but it dosent hold at all... when i got the car it would hit the red line before it shifted under full thottle... now it shifts much earlier. also if im going 60 and try to acceleate nothing it'll go but way slowly and not hold boost. like sometimes all just hold it at meaby 7 to 8 psi ad whatch the neddle fall... even though the trottle is at the same position... this is bad i figure i have a leek because of this and some hissing from the engine bay... you dont think its the turbo? Or ic?
i was planning on replacing my ic pipes anyway but i guess all also need a BOV... and i only have enough money for one or the other... alas... i reall hope its just a loose cupling ad not a broken turbo, or crakd ic
What should I Do?
What should I Do?
