JDM engine
rsh350
Jun 4, 2002
Does anyone know the difference between the red top and the titianium top 4g63 engines? or a place i could find out the dealership here is all stocked up with morons.
The JDM motor came with a possible 16 G and 550 cc injectors. It also came with 9.0 to 1 compression I believe it was. You can still get it with the same turbo and injectors as over here so you must specify if you order.
the red tops are usually from the galant vr4s and 1g eclipses in japan. and if your lucky, you will get one with a red valve cover and yellow injectors, because if you get the one witht the yellow injectors, you will get a big 16g most likely. and the titainium color valve cover are from the earlyer evo's.
