How to recirculate Blitz BOV?
jonnygsx
136
Dec 20, 2002
Ok, a guy in my area is selling full upper I/C piping w/ a Blitz BOV for a good price. Problem is that I don't have a fuel computer so I can't run with an open autmosphere BOV (I've tired it doesn't work). My question is in regards to the way the BOV is built. It comes with the ability to bolt on a filter or an air horn, has anyone ever bolted on just a pipe and ran it back into the intake pipe. If I could find a part that could be bolted on and routed back into the intake pipe I think it would work. Anyone know of a company that makes a part such as this, or if it can be done?
Jon:dsm:
from my experience with mine... you can get someone to custom weld it (i haven't gotten around to that). or with the stock recirculation tube you can force the air filter part into it (lots of forcing) but it'll work and then just hook it back up to the bov tube. however for me though the flange on my intercooler pipe has the bov like angled downward and so the turb will not reach or bend enough to get on the return tube.... im pissed and have been looking for ways to fix it or i might just eventually have to get it custom fabricated.... but basically just use the stock routing tube over the air filter and it'll work.... or cut away part of the airfilter if you're having trouble.
Check out what I did by searching ' blitz bov' and my username, 'jrtnos'. I re-routed using radiator hose and the stock dump tube. Works awesome. eme with q's.
