Nik
- Aug 4, 2002
Hey...
What size injectors are you guys running with the FP green turbo, or recomend using?
. It's 4wd, turbo, without ABS & I think it's just like 90 GSX Eclipse. I bought the car last January with 105Km clean & stock. Then I swapped all the mods parts from my 91 GVR4 to GSR-4 Eclipse. I'm looking for digital camera to post some pics for it.Originally posted by rdrkt
I dont understand what this macho thing is with injectors. Get a decent sized injector so you dont have to run a ton of fuel pressure and max out your fuel pump. Tsi92 to some extent your choice in EMS will also dictate your injector size. For a system running a batch fire injection you will need slightly larger injectors that compared to a vpc/safc.
For a Green I would go with a 720 or a Bosch 750 whichever you can find cheaper.
