Spike3099
- Oct 3, 2002
New Milford,
Connecticut
Hey what do you guys think abotu the super 20g turbo by hanns racing? I was thinking off buying it, 10cm housing internal waste gate and it can hold up to 30 pounds of boost.
Not sure if I can leak the word out yet, but call them and ask for Wade. Tell them Kevin sent ya!Originally posted by Unreal
I don't know why, but AGP has only sold a few l3rs. More people think they are too big or something. The l3rs are getting full boost around 4100. They make crazy power on pumpgas. I've had an l2r and l3r, and the l3r owns the l2r. Makes way more power, for only alittle bit more lag. People should seriously look into getting an l3r.
super lag......Lag is way over rated. But in your case its a blessing Mr 2wd.Originally posted by Phoenix_RsX
super lag......
. I guess you are right tho, cause I'm the only east coast dsmr around here that is, that's even heard of AGP. to the guy that said Hrc sucks ass. nothing personal, like i said previously, not trying to question what you may/may not know, but if you believe something sucks, at least tell the guy why.
Originally posted by asian312
Right now the name of the game is KISS (keep it stupid simple)
be
, sorry trying to fight off Def Com sinus attacks
!!!Originally posted by asian312
ItsStockOfficer are u so sure about that? B4 u are quick to judge, let the turbo get some life into her. U're absolutly right in saying that it may be a piece of junk, but until it gets a chance to, I nor u can pass judgement.
Reason y I directed them towards that is b/c they were interested in a 20G for the 2g cars. I agree on your opinion about the Hahn set after doing the research, and with that same mind set, is y this turbo was created. 20g characteristics with 2g install.
So is that all it's compared to, a big16g?. The 46 trim is larger than the 20g wheel. I'm no guru on turbos, but I do understand the need to match parts correctly. Will this work, who knows? That's y I stepped forward to try it out. If infact the comp side needs a revamp, yes, the larger T4 comps can be used. As well as the wheels. Right now the name of the game is KISS (keep it stupid simple) and with the hot side all being Mitsu and the flow side being Garret, it does just that. The parts match correctly with out any detrimental tinkering.
I trust Turbochargers with this build and I believe this turbo will be every bit as effective as the 20Gs. Somethings u just can't say, but take a closer look at the BR20. Not trying to hate on anyone, just introducing something different and new.
Your statements are valid, but I believe certain things are not being taken into consideration. It's something I've had to ponder about for quite sometime b4 posting this responce as to insure accuracy. Not to mention when I had to recall this discussion with some friends and developed a major headache when having to mix engine dynamics w/ physics.
Thats awesome, its great to see someone who actually does research!
The majority of this info can be further drawn from:
http://www.dsmtuners.com/forums/showthread.php?s=&threadid=22470
It's a very informative thread about what really counts.
Basically this is my approach, and I could very well be off on a tangent or cloud 9, but here goes. Summing from various sources, the approach to turbos using PSI and CFM's is only one half the equation. From what I've been able to draw, it's the ability of the turbo to feed the demand of the engine and the ability for the engine to exit that flow. True that one turbo may have the ability to make more HP or PSI than another, but it's more along the lines of how efficient it is at doing it over various RPM ranges. 15 psi form a T-25 is the same as 15 psi from GT-30. What's different is the amount of CFMs being delivered and its effiency. As RPMs rise, so does the flow of the engine. More revolutions = more complete strokes = higher flow out of the engine. It was explained to me that an engine is a closed system, and with that in mind, u can only flow in what u can flow out (this is 0 boost). When your turbo supplys more than the demand u create boost which in turn creates a more dense air which = more power. Now the differences in turbos come into play at how efficient they are at supplying that required CFM. The more efficient the less energy is lost in the creation of heat. Y the TDO6H wheel, less restriction
This is all true. Of course you don't want to have a 300 hp compressor wheel and a 500+ hp exhaust wheel. Then again, its experimentation with a new system and Im anxious to see what it will do, this may be a good way of doing things.
So more importantly it's about where the bottleneck in your system is (IC, exhaust, head, etc.) and what Pressure Ratio u are demanding from the turbo at various RPM ranges. This inturn draws more upon the effiency than PSI and CFMs. Now I realieze the approach u are coming from, in saying that the tdo6 20g flows ~51 lb/min at 20 psi, the 46 trim maxes out around 45 lns/min. But how efficient is that? According to some simple calculations, 51 lb/min = ~.33 m^3/sec. Follow that on the comp map and u'll see that it's way off the effiency islands (below 65%).
I don't see that, I see .33-.34 on the 68% eeffciency line@ a P/R of 2.25. The 46 trim hits max mapped airflow at the same around the same PR....but its ~44 lb/min AND ITS MAPPED TO 60%....not 68. Tell me this isn't an extremely large difference? And remember, the 46 trim is mapped in a TO4E housing, in a T3 housing its going to be considerably less effcient, on the order of maybe 4-10%, with the larger losses being at high boost(and DSM's boost HIGH, near the top of maps).
Keep in mind, generally these numbers are generated from a flow bench which does not impose the same restrictions as our engine does (maybe wrong on this one, I'll have to check in the morning). As so, the 20g is capable of higher top end, but the comp maps are very similar in nature in comparing the effiency islands.
A flow bench covers every load, then you map an engine accross it. You take your pressure ratio. I run 19-20 psi so mines about 2.8. then you draw a flat horizontal line accross. The left side of the line will be low airflow(low rpms) The right side will be high airflow and RPM's. Anything that cause boost to change, (creeo, crazy boost controller's, small turbos) will cause the line to not be flat horizontally but move up and down as it continues right.
The fact that it is a hybrid does not mark it as a doomed for failure. Alot plays in the design and how parts are matched and pieced together. Due to professionalism and courtesy to all Turbo shops, all I will say is that some hybrids are created right and some cut a few corners. True the design of the 20G has withstood the sands of time, but once again this is still new. But the internals of this turbo has been carefully chosen to meet it's requirments.
I dissagree with them being carefully chosen. Why a T3 comp Housing? A to4e housing fits fine and greatly increase's effciency. FP makes a sleeper 16g, its a 20g in a 16 compressor housing. It makes 30-50 less max whp. A comp wheel should be in what it was designed for, ro something close(TO4E/TDO6-T3/TDO5H). the 46 trim is not matched to the turbine wheel well. Its the same turbine wheel as 500+ hp RED which uses a mystery compressor wheel, but something like a 62-1. Its the same compressor wheel as a Frank 1. So its either a DISGUSTINGLY underpowered Red or a Hugely exhaust upgraded frank 1. Either way the compressor wheel is a significant limiting factor. I assume the T3 compressor housing is chosen MERELY because it mates with the t3 center section which is chosen MERELY because is has the same bolt holes as a stock 2g? Id rather tweak my lines and get a significantly better turbo.
More top end HP does not always nessessarily mean more applicable power. There's many "outside" variants that will also play into effect such as what supporting mods. Is it worth the money? Although I can't disclose my personal situation, I was told it would be in the ball park of ~$1200. Compare that to a "NEW" 20G TDO6 at ~$1000 plus the 2G install kit, they come out about even. Where this may draw attention is that it is a bolt on and that it is still just a variant (1st of this type). I've been told that different comp housings and wheel combo can be applied. This is just a starting point. We'll have to see after I get it on a dyno. The 20G is an awesome turbo. Proven time and time again. But as in all things, majority of the time it's about the driver/tuner and not the equipment. For now, I'm out!
A better turbo will generally make more power and at rpm it has boost. Even a 60 trim will have all the power band it needs for drag. your compressor wheel might be good for road racing, but the turbine side makes that impossible neways, TDO6H is HUGE. The GOD of 46 trims as far as im concerned is Scot Grey(www.dsmporn.com) at 11.91@117 on C16(VERY high octane)....My 20g did that on 110 so easily its not funny
Merry X-mas!
Merry Christmas!
