JeffreyS
- 69
- Jun 3, 2002
Winfield,
Illinois
I have a problem bothering my 91 Talon AWD 5spd and was hoping that other people may have seen this and may have some idea of where to turn next (I'm tired of taking it to a shop and having them probe around with no clue of what to do)
My car's problem ONLY happens when the temperature is up to normal (so it doesn't happen when the car first starts).
When I start the car, I can accelerate at full, mid, or low boost (let's say 15, 10, 5 PSI) with no problems. However, when the car is warm, and I try to accelerate at non-max boost (10 or 5 PSI), the car will jerk or buck UNTIL I let off the accelerator. If I keep the car under boost (0 PSI), NEVER does this happen.
Possible coincidence or contributing cause, the check engine light may come on before or after this happens, but is intermittant, and doesn't necessarily stay on.
A local shop attached a computer to the car and read the code to be "low voltage", at which point the alternator was replaced - that was the last time I've had the car in to the shop.
I've done an ECU reset (to my knowledge - disconnected the battery for ~15 minutes, turned the iginition key a few times to dump the capacitor charge, and reconnected the battery), but the light still comes on (this was before the alternator was replaced).
Parts replaced: sparc plugs wires (replaced with new Taylors), MAS, alternator
The boost controller is fine, the blow off valve is fine (or else they wouldn't operate normally and hold boost, right?)
To throw one last wrench in the works, if the check engine light does go on, and I get the bucking bronco effect, I've found that if I let off the acceleration, and then floor it, there's no hesitation or delay in response!!!
Any help would be greatly appreciated!
