Lash
- Dec 16, 2002
K, I know there's already a thread about a JDM swap goin on just a few posts under this, but I wanted to make sure I got everything I need before I start this. I'm only gonna have a week or two to do it, and don't wanna get stuck without having a part. If I don't finish in that week or two, it's gotta wait 3 months..
Anyways, I bought a 90 Eagle Talon. Right now all it's got in is the bottom of the motor. And there's a nice big hole in the block. So that's getting trashed, but the oil pump is still on the motor, and looks salvagable. Also, the front differntial is there, as is the driveshaft, and the rear differntial.
I'm buying a JDM motor, tranny, and transfer case from a friend of a friend in Toronto. A bunch of the honda guys around here have done swaps with motors from him, and all have been good engines.
Anyways, I need to know what I need. So far I've got this list...
Cam Angle Sensor
Thermostat Housing
Water Pipe - Below and Behind the exhaust mani...
Power Steering Pump
Compressor Outlet Elbow
Oil Cooler - 90 DSM
NGK Spark Plug wires - Longer so they'll fit the JDM motor.
Spark plugs
Belts, and fluids
That's what's on my list, plus I'm going to be getting a ACT 2600lb clutch, and debating on a balance shaft emliminator kit. I was just wondering if you guys knew of anything else I should get, just in case...
Oh ya, it doesn't have an ECU in it right now, and I'm lookin for one at the moment, I know it has to be a turbo awd manual 90 ecu, but is there anything else I should look for? Thanks...
Cam Angle Sensor
Thermostat Housing
Power Steering Pump
Oil Cooler - 90 DSM
Spark plugs
Belts, and fluids
