twistedcm2
- 37
- 1
- Mar 20, 2005
Denver,
Colorado
So about two weeks ago i replace my isc. Well when i did that i also out a different tps on from my buddies motor he has. So car was good but i would get a cel and it was for tps. So i read up on how to set it and didnt has access to a volt or ohme meter. So i just set it at 10% at idle with a logger. So everything was fine then last night i went driving and did a pull let off and let the car coast. I put it back into gear and i notice that when i would hit the gas it would take a second to transfer to the engine and would stumble really hard then be fine. So i pull over and get out and rev the engine from the throttle body. If you rev it to like 1,500 slowly it gets stuck almost like a studder box. When its in this mode you can open the throttle all the way and nothing happens it just stays studdering. So i drove home and its still doing it and almost feels like theres something blocking it but once you get past it the throttle feels normel except for the lag. The only thing i can think of is to just rebuild/or find another throttle body. Also when changing TPS we noticed that the seal was bad and leaking so i'm not sure if that would have to do with anything. Sorry this is long but i wanted to try and explain whats going on the best i could. I would appreciate any feed back thanks.
