linksys42
- 412
- 30
- Jan 8, 2003
Union,
Missouri
Hello, I have been having this prob for sometime now if anyone has any ideas what this might be I would greatly appreciate it. I have a B&M fuel pressure gage kit that mounts to the banjo bolt on the top of the fuel filter and with the vacuum hose disconnected on the fuel pressure reg. I am seeing 48psi, with it connected at base idle it is right at 39-40psi???? This is on a totally stock fuel system. What could be causing that high of pressures? Stock with the hose disconnected should be at 43 psi and connected it should be at 33-35psi at idle right??? My vacuum at idle is right at 19 inhg. It would be great if someone could help me to figure out why is so high. Thanks
