T3/T4 Turbo HP
98gsxdude
Whats the most HP you can get out of a T3/T4 Hybrid Turbo...Below are the specs
T3 .48AR Stage 3
T4 60 Trim B-Housing .70AR (Not a 60-1)
Get a .63 AR turbine housing and I believe that set up is 500hp. The 48 will improve response but keep its efficiency low. The 60 trim is peaky cuz its size so its compressor map is long and angled with a thinner peak efficiency. that set up is like running a 20g with a 6cm turbine housing. My 0.02
98gsxdude: I can tell you that on my 91 gsx I have a T3/T4 to4e 50 trim with a .63 a/r stage 3. I had my car on the dyno once, It made 350whp and 344wtq. The only problem I had was that the power was made with the boost controller set at 18psi with a huge boost leak!!!! I was very pissed off at the car that day. So needless to say the car made great power for the the boost leak it had and running on pump gas. I think with the turbo I have the car will make hopefully anywhere from 460whp to 480whp and tq not too far off on race gas and 28psi. All this power is going to be on stock bottom end. That is my info that I have about my t3/t4, When I get the car back together and take it to the dyno I will post the dyno sheet and hopefully my goal will be made. Hopw I helped talk to you later.
Ed
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
