99blackgst
- 48
- Oct 10, 2002
i just installed my a cyberdyne a/f gauge today. i found the pin out and hooked the power and ground wire to my cigarette lighter, and the other wire to the O2 sensor on the ecu. when i first started the car it read lean for about a min. and it slowly climbed to the top at rich. it has been reading rich since it climbed to rich, even when i put turn the key to accesories and turn the gauge on it still reads rich. what do you think the problem or cause is?
my mods are stock T-25 running about 13psi , dejon ic pipes, dejon intake, greddy type-s bov.
my fuel pump and injectors are stock, i haven't ever touched the maf sensor screw
