Marc91GSX
- 521
- 6
- Jan 20, 2006
Apopka,
Florida
Ok I have several problems but only two that I cannot figure out.
Problem 1) My car has a major missfire and I am lost on what it's cause might be. At an idle I can pull the injector plugs off of 1 & 4 the idle barely changes, but if I oull them off of 2 & 3 the car almost dies. As the rpms increase the missfire seems to go away until about 4000 rpms and then it comes back with a vengence. It literaly sounds and feels like I am hitting the rev limiter. I have tried all of the free test that I can think of to narrow this down or fix it but so far nothing has worked. I have swapped coil packs with a known good unit, switched injectors, done a compression check, replaced the plugs, and even gone so far as to pull off the cams and check the lash adjusters to make sure they are not holding the valves open.
Problem 2) I can not get anything to communicate with my ecu. I have tried my laptop with DSMlink, my regular dattalogger, and even a factory scan tool.
I am lost on both of these problems and I am about to give up. I have been fighting with this thing for the past four months and if I do not have them resolved soon I am just going to part this POS out and burn what does not sale. Please help!!!!!
and check the wires there as well.
