Galaxy
- 284
- 2
- Aug 17, 2002
Gainesville,
Florida
I have a 92 eclipse GS thats stock.The fuel pump died and I'm putting one in from a 93 Tsi.The rubber grommet that supports the pump on the hanger at the bottom does not match up.I can get it to sit where I think it will work fine but I'm going to end up using a hose clamp to hold the pump to the bracket.Is there ant reason I can't do this? Even if I could get the correct grommet,it will not fit the hanger from what I can see...the Tsi pump is alot larger than the little NT one.Is there any reason the actual pump body needs to be insulated completely from the hanger or can I just hose clamp it on and be good to go?
