ZigsGSX97
- 113
- Apr 30, 2004
Hickory Hills,
Illinois
ok....so I've had this vibration problem with my engine ever since I got the car 3 years ago. Whenever I rev it up between 2500-3000, my transfer case VIBRATES!!! horribly. Now I've replaced the transfer case fluid and that didn't seem to do it. I have also talked to transfer case experts and they said if it's making the vibration when in neutral, then it's not the transfer case! So next i moved onto motor mounts and found that 2 of them were bad. I replaced them, but still the nasty horrible vibration. Then I checked my balance shaft....no play and the belt has just been replaced. I'm running out of ideas. I have to get my car dynoed and tuned in less than a month and i was hoping to get rid of this damn vibration noise.
Also......my timing belt jumped a tooth and the plastic casings that surround the timing belt were broken beyond belief. I replaced the timing belt and it's running like crap now. It idles very poorly. Do I need to break it in and drive for a while or what? And when i go to boost, the turbo spools, but no go. Is this because i have 550s and no tune for my safc 2? A lot of questions....hopefully you guys know some of these things
