out there
- 1,276
- 2
- Nov 8, 2002
Fargo,
North Dakota
ok, i don't intend to hit the track often, maybe a couple of times so i can get some #'s for all of you fanatics...
i just want something that can hold it's own against most of the other cars on the road and still be daily-drivable. this is a basic list of stuff that i intend to do to my car (all stock, just bought it in june) in the next couple of years, the approx cost (i plan to buy used when it won't sacrifice quality), and approx order. it just came from a few moments of thought without any brainstorming. each year will probably be done all at once at the beginning of summer because my car will be in storage all winter and i will be acquiring the parts all the time it's in storage.
*year 1*
dual stage boost controller 90
3" o2 elim, no cat exhaust 900
boost gauge 25
egt gauge 25
2g mas 50
supra pump 150
act 2600 300
2g throttle body elbow 50
*year 2*
fmic 1000
super afc 400
660 injectors 200
2g pistons and rings 450
*year 3*
2g exhaust manifold 200
new turbo, undecided about which, probably bigt28 killer 800?
wastegate (depending on turbo) 300
blow off valve 150
*after turbo*
lightened flywheel 400
lightened pulley kit 250
lower about 1"
lighter rims and very sticky tires
new gearing...
i would really appreciate some feedback about this list from those of you that really know your dsm's. if i should get something done earlier, or later, and if i missed anything, please tell me. as you can tell by my time frame, i intend for this car to last me a long time. if there is anything that you recommend doing to ensure a long happy life, don't hesitate to tell me. pm's and emails would be appreciated so i have something to keep on record for future use.
i just want something that can hold it's own against most of the other cars on the road and still be daily-drivable. this is a basic list of stuff that i intend to do to my car (all stock, just bought it in june) in the next couple of years, the approx cost (i plan to buy used when it won't sacrifice quality), and approx order. it just came from a few moments of thought without any brainstorming. each year will probably be done all at once at the beginning of summer because my car will be in storage all winter and i will be acquiring the parts all the time it's in storage.*year 1*
boost gauge 25
egt gauge 25
2g mas 50
supra pump 150
act 2600 300
*year 2*
fmic 1000
super afc 400
660 injectors 200
*year 3*
blow off valve 150
*after turbo*
lower about 1"
new gearing...
so changing the manifold to get some practice at removing a turbo wouldn't be the best reason to do it. once this car is done, then i'll start on something new that i can sell to some kid that wants a fast car for very little $$ (ie 13sec eclipse for under $2500).
