how much boost?
GavinTsi
Oct 24, 2002
hey i know this is a stupid question, but first, how much psi should my stock turbo be puttin out, (1990 talon turbo awd), second, my gauges are on the way, what should i put the boost up to safely, when all i have i s k&n filter
p.s. wht is the name of the stock turbo, ex. 14b or whatever.
thanks alot for the help
Mat
The stock 14B should run around 11psi in stock configuration. With no other mods, you can safely increase the boost a few psi to 13 or 14psi. Make sure you follow the tuning guide on this website for all your initial mods.
Good luck
