CH152
- 296
- Oct 8, 2002
Lexington,
Kentucky
(I'm not for sure if i am the first one to come across this or not?)
I really was not paying attention to my Boost Gauge in Neutral until today. Yesterday I had installed a MBC from Mc Coy Motorsports www.tobefast.com . The name of the MBC is Applied Technologies & Research, INC CV100A. Anyhow according to the instructions you are to remove both line on the BCS valve and set them aside. The two lines you took off the BCS valve, the upper one I think goes to the bottom of the intake going towards the turbo inlet (plug that nipple off on the intake with a vacuum line and a screw) and the bottom one goes to the turbo and has a T fitting, one line goes to the Wastegate and the other goes to the bottom of the turbo compressor. Now back to the installation: My MBC came with a controller and one line that splits in a Y fitting. One goes to the Inlet on the Turbo compressor and the other one goes to the wastegate, which technically is a signal port, which then commands the wastegate diaphragm to lift or open. After its installed ty-rap the vacuum lines from the MBC so you cant get any leaks. HOW IT WORKS: Opening the valve bypasses air away from the wastegate/signal port. The restriction in the Y is being worked against by air bled away with the valve, Simple and effective. The 2 nipples on the BCS I just left untouched. When I was looking at my boost gauge in Neutral I was building 13 PSI ( I had my foot in the gas though, when i wasnt touching the throttle it was pulling -18 pounds) no joke about it. I dont know exactly why it is but the turbo is now boosting when I am at the line before I take off ( foot on the gas at about 4500 rpm). Pretty neat huh? Let me know what you guys think. Here is a pic I made to help some in the explanation.
I think I'll keep dreaming though.
anyhow, if i could get a video to show you all i would but our technology in kentucky is not to advanced where i am from. Anyhow, i am not complaing about it building boost in nuetral. its not like i barely touch the gas in nuetral i go from idle and floor it and it builds up. Its confusing at first reading all this abotu how it works, but it shocked the piss out of me cause i didn't think it was possible without one of those stutter boxes some people have.
