Need Answer Asap!!
DSM BLUE TURBO
109
Nov 27, 2002
Really fast question guys. Will a external dump o2 that fits td05s and garrett turbos fit the stock t25? Besides it being VERY loud, another downfalls of a external dump?
the t25 on a dsm uses a mitsu turbine housing, not only will you beat/ lose to your opponent but you will make them deaf too. exhaust gases are being spewed out into your engine bay. you just need to make sure that your dump tube is long enough
if you live in an emissions area you wont pass
with the dump you will have no boost creep and a loud exhaust <sounds bad ass> but as you can see you will not pass emissions <thats if you have them there. it will fit the T25 you will pick up a few hp in there.
I highly recomend the dump ....... but if you dont want a loud car uner boost then go internal O2 houseing ported.
Later
Rob
