larryd
- 4,546
- 5
- Nov 26, 2001
Bear,
Delaware
Hey guys I just got alot of little issues on my car fixed up such as.
I only had a 0.4 bar spring in my wastegate which obviously caused
my wastegate to open WAY to soon. I now how have 1.1 bar spring in
the wastegate which is allowing me much better boost response.
I had a pretty large boost leak between the head and the intake
manifold. We pulled the intake manifold off yesterday to see the
surface was gashed from something. We replaced the intake manifold
and voila, no more leak.
I changed the plugs to a new set of NGK BP7ES gapped at 0.28, the
plug wires have been changed to Taylor 10.2mm wires, and the coil
pack was swapped out for a 91 style that I knew was working since I
had some issues with mine.
We cleaned up the surface for the knock sensor to make sure it had a
good ground and put a rubber washer on it to dampen it to try and
cut back on the knock sum I was see'ing.
From the general butt dyno the car is pulling harder now at 15psi
then it did at 20psi before but Im see'ing some pretty bad knock on
and I dont know how to defeat it.
Ive uploaded my log to my webserver, you can see it here if you have DSMlink or you can see the HTML version Ive linked to on that page as well..
http://www.newcelica.org/larryd/log/log.htm
Here is a copy of the default notes so you can see my DSMlink
settings.
RPM Fuel(%) Timing(deg)
500 0 0
1000 0 0
1500 0 0
2000 0 0
2500 0 0
3000 0 0
3500 0 0
4000 0 0
4500 0 +1
5000 0 +1
5500 0 +1
6000 0 +1
6500 0 +1
7000 0 +1
7500 0 +1
8000 0 +1
Global fuel: -31%
Dead time: +180 us
As you can see I havent really made any changes to the fuel. I have
yet to set the LTFT and STFT as I just got the car running right
again last night.
Couple last things. My fuel pressure is still a little low. I have
a Charged Air AFPR and I have the lower base spring in it so I can
only get the fuel pressure to 40psi with the hose on and 30psi with
the hose off. I have to put the stronger spring in to get it up to
43psi but I did not have the right tool to do this yesterday. Damn
Charged air and their hex heads
Lastly my base timing is set to 8 degrees both on DSMlink and with a
timing light. We set them as close as possible, the DSMlink was
showing 7-9 degrees at idle and the timing light was showing 7-8
degrees at idle.
Im going to the dyno in 2 weeks and Ill be tuning with a wideband o2
but Id like to see if you guys can offer me any advice on my knock
issues before I head to the dyno.
One last thing, I had an encounter last night. I ran this LS1 TA on the highway last night. From a 65mph run in 3rd gear I pulled 2 about 2 car lengths on him to 100-110 ish at 15psi.. I was pretty happy with that.
settings.
500 0 0
1000 0 0
1500 0 0
2000 0 0
2500 0 0
3000 0 0
3500 0 0
4000 0 0
4500 0 +1
5000 0 +1
5500 0 +1
6000 0 +1
6500 0 +1
7000 0 +1
7500 0 +1
8000 0 +1
Global fuel: -31%
Dead time: +180 us
again last night.
degrees at idle.
