Talesin
- 1,718
- 36
- Jan 19, 2005
Burbank,
California
I've installed a Walbro 255HP and an Aeromotive AFPR; the problem is, the stock FPR keeps 21psi in the fuel system when it's turned off, to make starting easier. At the moment, as soon as the key is off, the pressure drops to zero, forcing a longer cranking time. Is this supposed to happen? Is there any way I can alter the behaviour back to stock with the upgraded fuel parts?
I'm just worrying that I'm over-wearing my starter, cranking it for 5-10 seconds each time, instead of the 1-2 for a 'normal' car. I'm also concerned about air/vapor bubbles in the fuel lines possibly lingering, and making their way into an injector at a bad time, like under full boost.
Or would the question better be put... is this normal behaviour for the fuel upgrade parts, or should I get my mechanic to pressure-test the system? I haven't checked for a cocked o-ring yet, wanted to make sure it was still SUPPOSED to be holding pressure with an aftermarket FPR before I had to deal with that bastard of a line fitting bolt again.
I wonder if a stock FPR could be plumbed in downstream of the Aeromotive, to try to hold that stock 21psi from falling through the return... adding a new potential point of failure, but it could be worth it. Wouldn't want to put it in before (as I already have a rail fitting and would worry about pressure leaks from the return side), but I'd be concerned about erratic behaviour downstream, if the stocker made for any appreciable backpressure on the return line (possibly giving me an unstable fuel pressure rise under boost).
Or a three-position switch.
