fuel cut
DSMturbo
hey guys - i just bought the turbo xs dual stage boost controller - i havent hooked it up yet - but once i do how do i get rid of the fuel cut??
its kinda hard to tell, because you have not listed your mods or boost level. if you are still useing the 14b, on a stock fuel system keep boost at 16psi. (MAX) then remove, the lower honeycomb in the mass air meter. i didnt get fuel cut until i got my 3" d-p and test pipe. before you start adjusting boost, make sure you have a boost gauge and a/f gauge. hope that helps;)
Ok- ive removed the intake silencer with a opened airbox and k&n, i have a 2.5 down with a 3" catless exhaust - that does help - thanks
*leaving to take the honeycomb out* : )
