Spln_Hrd
- 1,707
- 8
- Oct 20, 2003
Hastings,
Nebraska
my new 750's make my car run like poopy until it gets warmed up a little anyone know why? they work good other than that
Spln_Hrd said:my new 750's make my car run like poopy until it gets warmed up a little anyone know why? they work good other than that
andymoraitis said:If your profile is correct and all you're controlling them with is an AFC, then it's way out of the AFC's correction range. Pulling your plugs will likely show plenty of black deposits and buildup. Injectors over 650cc should be controlled with something that will allow you to better adjust the deadtime and global settings such as DSM Link or a chipped EPROM ECU with injector compensation. Also, if you're really still running a 16G, why such large injectors?
Hope that helps,
Andy
