6 bolt block swap qs....
highintenzity4
221
Apr 30, 2004
Mission, Texas
Hey is it possible to move to a 6 bolt with my 2g head? I have an a/t.. so what else do I need to do this job? Thanks...
Wolf just did one the same way....it will work fine. I am assuming it is going to be the 2g intake and TB?as long as you have the front case and oil filter housing for a 6 bolt and the timing parts You will be ok and good luck.
Julia :talon:
Julia :talon:
Your going to need more than juse the front case, oil filter housing and timing parts. But yes, it can be done, and its the way I'm doing my swap as well.
Do alot of research on this site, as well as read up here:
http://www.magnusmotorsports.com/article_1g2g.htm
Good luck.
-Nick
