Venting to Atmos?
0pie
Nov 13, 2002
Albany, Oregon
I just got my 95 Tsi, and the blow off valve seems to make a wierd noise. It flutter's in a way, instead of the high pitched noise common.
Idle seems to be sparatic aswell.
Originally posted by Megaman
that my friend is compressor surge. like a chh chh chh stuttering noise right? try loosening it.
greddy.com has instruction on how to adjust the bov...under faq.
wrong
that means its super loose, my RFL flutters at 2 psi. tighten it a bit and the fluttering will go away
If you get compressor surge that mean the BOV is too tight and it's not opening at low boost. Does it happen when going under boost and then you slowly release the trottle?
"...Generally you want to valve as tight as possible, without getting any compressor surge. (Compressor surge will sound like a stutter.)m You don't want it too loose or it can open too early and you will loose boost. The valve should make one clean blowing sound, it should not stutter. It should also not open before the throttle is shut."
from greddy.com
uhh yup...that means its too tight...loosen it a bit
