everything for an ignition
iwantawd
243
Jul 31, 2002
Reading, Pennsylvania
i know absolutly nothing about ignitions and ive been trying to research some stuff but what is everything i should replace.
plugs
wires
and then what...
msd dis 2 (is this just for a stronger spark)
what else
any info would be appreciated:dsm: :thumb:
You don't need a new ignition box. You can try that coil-on plug ignition in the thread at the top.
Just change the plugs and wires and that's enough.
Why are you wanting to replace everything? Start off with a new set of plugs and if you feel spontaneous and your stock wires look wore, replace them too, and testing the coilpack and transistor as per the manual, as well as checking your base timing. 9 times out of 10, plugs and wires are your problem. After that there is the coil pack, transistor and then finally the ECU.
Are you having problems? What are your symptoms?
i was just wondering i thought that was just kind of a common thing everyone does.
