bdffej
- 48
- Oct 7, 2002
what is the max boost i can run on a stock 1991 eagle talon?
Originally posted by BatmanGSX
18-19 is about all the stock turbo will happily do. After that it gets hot.
The worse condition your engine is in the more boost you can run. Don't believe me? When your blowing all the pressure into the crank case anyway, you are less likely to get knock. My friend used to run 21psi on pump gas with a 16G, stock injectors, 90psi compression across the board![]()
Pumpgas = 19psi - 20psi
Race Gas (116) = whatever the turbo can give
With stock injectors the AFC is virtually useless. Messing with it much (adding fuel) will cause any number of badness, such as fuel cut or bad timing. Your key will be watching knock. 19psi on a B16G probably won't damage anything no matter what but it may kill your timing. Watch the knock and boost away.
I dare not even push a 14b that high.Originally posted by Kyle90GSX
I dont think it would be such a good idea to go that high on the stock sidemountI dare not even push a 14b that high.
I'm sure you cant be talking about pump gas.
