DSM1gTalon
- 36
- Dec 8, 2004
Philadelphia,
Pennsylvania
I tried searching and vFAQ and I couldnt really find anything so here is my dilemma...
I got my buddy to hook up my 190 pump for me a couple weeks ago but the next morning when I went to go to work I blew my ignition fuse. I unplugged the harness to the pump and threw in a new fuse and figured out the problem was with the pump. When I went to take the pump back out I broke the fuel line coming from the sending unit so I got a new one. That came in over the weekend while I was away and yesterday I tried to install it myself. Using the other assembly as a guide I hooked up the wires and pump and everything looked fine to me. I had the power wire and ground hooked up to the top (round part) of the assembly and dropped it in the tank. Tried to start and nothing. Took it back out, put the ground wire on the part that holds the pump (the long part that sits in the tank) and put the power wire where I had the ground and tried again...still nothing.
Now I am out of ideas. I was told I may have shorted out the pump but how would I be able to figure that out?
Any help would be appreciated, thanks.
