Projectpat115
- 39
- Jun 9, 2004
Waterford,
Wisconsin
Just finished a motor swap. when we started it up i noticed the oil presure gauge was at high, it was just about all the way up, we turned it off and the gauge stayed up so my friend thinks it is broken. is the oil pressure gauge suposed to go to zero when car is turned off? the car runs great, perfect with no idiot lights at all. I had the car parked for a while and noticed a small amount of oil under the car. there are like three different spots, it is dripping like oil got sprayed under the whole left side of my car. the is oil on the axle and oil filter housing. i also notice some up by my a/c belt tensioner and on my oil pump sprocket. the leak is very small. just wondering where this might be coming from. my belts do sweal on start up so i think oil may be on them.
thanks
pat
thanks
pat
I had this same problem. It turned out to be either my pump sprocket seal, or my castle plug seal. Its a bizznitch to get to all those things, but hey, get it done right and never worry about it. Having confidence in your ride is SUCH a lovely thing.
