2 fuel pumps?????
4g63telantra
454
2
Dec 10, 2004
Toronto,
K ill be running a walbro 255 intank and hose fuel lines in the engine bay, just wanted to know can i cut the fuel hose in the firewall and add a INLINE FUEL PUMP in between them?
ex. Intank pump--->fuel lines--->inline pump on fire wall--->fuel rail?
you could i guess, but I would put the additional FP by the tank.. the wiring is all ready there and so on.
Why do you want another FP?
What do you plan on running that requires you to have 2 pumps? You don't need a 2 stage fuel system on your car, it's not an airplane.
There are people on here with 190 pump running 50 trims at 22psi on pump gas. Granted you have a dry nitrous system so you need more fuel, but 1st, you should have gone with a wet or direct port kit instead and 2nd, a 255 will be enough for your turbo and the nitrous.
