umustbconfused
- May 17, 2005
Maryville,
Tennessee
I bought the saf-c 2 for several reasons with one of the main reasons was to eleminate the "blow back" due to a larger front mount. To my disappointment according to the installation book and the wiring diagram i'm unable to use the feature. The wiring diagram given in the manual for my car is Karmin setup but in order to read the intake pressure in need the hot wire/flap diagram. Is there another route that I can take to make it work with the saf-c or any other way to keep my car from trying to stall out after boost? It only happens when i'm in boost and then hit the clutch. Another question that I will add to this is that my car starts running really rich at about 12lbs of boost. I never had this problem until I ran 110 fuel through my car. I have since ran 3 tanks of 93 gas and I still have this problem. It seems that my car will stutter after the 12psi. I'm not sure if I should try to lean it out using the saf-c or not. I've ran 110 before and never had a problem like this before. If you have any ideas just let me know.
