Anyone get a Exhaust from DSM-Performance.com
irn__man
256
Oct 8, 2002
New Orleans, Louisiana
Anyone bought an exhaust from DSM-Performance.com? I purchased the following system :
http://www.dsm-performance.com/catalog/product_info.php?cPath=31&products_id=110
I purchased with the High Flow Cat and Test Pipe. My problem is for installation you have to start cutting the exhaust. Also, after the cat/test pipe the exhaust reduces down to 2.5" then back up to 3" . I am very unhappy with this. The 02 elimnator is awesome, I just don't like the fabrication of installation.
My plans are to remove the 2.5" section and weld a 3" spacer in its place, to get rid of the bottleneck.
Anyone else have this problem?
iron
It is common to have to cut a section off the catback exhaust to make it a true 3" exhaust system. I had to do that with my Thermal catback when I installed my DSM P O2 elimintor.
I have this for my 1g and its completely fine. The only thing i didnt like is that it didnt come with gaskets and bolts as well as how long it took to get here :mad: Other than that, mine is 3" all the way back. I ordered the 3" o2 elin turbo back with test pipe. Is it because you ordered with the cat or something, i dont see why or where it would neck down to 2.5" at all.
Its because alot of aftermarket 3" catbacks are designed to bolt straight up to the stock downpipe/cat. That is why is necks down.
I know that, but he said he bought turbo back.... that is exactly what I ve had on mine for months now, but mine doesnt neck down at all
Yes, I did order with the Hi-Flow Cat option. I believe that is why it is flanged. Attached is pics of the downpipe, 02 eliminator and the flanged section of exhaust.
iron
