12 Seconds?
TrbTaLoN
74
Aug 19, 2002
What all do I need to be running low 13 to a high 12??
I already have the following items tell me what else I will need.
Already have an uprgraded fuel pump.
16g turbo
BOV
3 inch cat back exhaust
boost and air fuel gauge.
What should I get next and what will I need to achieve my goal. ?
Try the tuning guide. It is very helpful and at the end of certain stages it gives an estimate of hp levels and such. You dont specify wether your awd or not, which makes a big difference. This is a very common question, so just hang aroung the site for a while, read up and do some searches and stuff and I KNOW youll find all the info you can ever want!!
he said he's already got a new fuel pump.
anywho, a next cheap upgrade would be to get a boost controller and turn up that psi on your 16g, and a K&N would help for not that much. Or u could open up your wallet and get bigger injectors and a AFC and a fmic. If you got FWD like me its gunna take a lil bit of cash to hit that 12 second mark compared to the AWD guys, they got a auite a bit of an advantage. hope that helps a lil.
Oh and hey candela, i'm still lookin for a 16g if u wanna go CHEEEEEEEEP on yours :)
Mod your MAS, run a test pipe, get an MBC and run some race gas, you should be able to hit 12s no problem.
How much does and upgraded exhuast manifold cost? I need one bad. and how much for and upgraded oxygen sensor?
You're best bet is to find a good 2G manifold and port it out. They flow more than the 1G and are good for 12's and even 11's. If you must get an aftermarket one plan on spending $500+ for one that won't crack.
With a manual boost controller and your exhaust unbolted you should run atleast a 12.9. With bigger injectors,S-AFC, hacked mas, and atleast a 2100lb clutch you should see 11.9 if you can drive. I still have a 14b and I run high to mid 12's now on race fuel and can't speed shift 2nd gear. Its all in tuning and driving....
kyle
A buddy of mine just went 12.9 and trapped 107.6 with a questionable trans with his 14b. Granny shifting and all. His only mods are 3" turbo-back, fuel pump, boost controller and 2g manifold.
If I get rid of my old o2 sensor housing can I just use my old sensors or if I buy a new o2 sensor housing do they come with the sensor??
-It would be best to just port your stock 1G 02 Sensor housing.
AND oh yeah,
-Buschur Racing sells a ported 2G Exhaust Manifold for $275.00
Thanx,
DeathBeast - 1993 Eagle Talon TSi AWD :)
no...you didnt misread, its common to get in the 12.s with very little or a few bolt ons. i was doing 13.002 @104 with just an k and n filter, and a very gutted stock exhaust, not even a mbc.
