dsb97gst
- Aug 15, 2002
Tucson,
Arizona
my vacum is at at when i am just cruing doing like 45 . i was wondering if this is right or should it be under ant bosst and showing atleast like 5lbs of boost?
Originally posted by Megaman
hmm....i only get boost on wot or when the turbo starts to spool up...but when i just slightly press on the gas(like i mentioned before) it still shows vac no boost at all...![]()
1. Tap the boost gauge hose into the hose that runs from the intake manifold to the solenoid that controls the fuel pressure regulator. This is the center solenoid on the drivers side of the firewall. Remove the double-ended hose connector on the bottom hose of the solenoid and install the tee in its place.
Some prefer connecting to the "P" fitting on the throttle body. Using this connection will not show vacuum on the gauge. The reasoning behind going to the P fitting is that by connecting to the fuel pressure regulator, you run the risk of loosing pressure to the regulator should something happen to the boost gauge hose. The solution is doing a nice job of connecting the hose and keeping it safe. By connecting to the regulator, you will be able to see if the regulator is getting pressure. Nothing showing on the gauge, means nothing getting to the regulator. With the hose connected to the P fitting, you could loose pressure to the regulator and never know. We like the connection shown, it is your choice.
