Help!!!!!!!!!
Status
Not open for further replies.
pimpinboudy
48
May 2, 2004
lambertville, Michigan
hey guys real quick i need some help fast! i just installed my new 60 trim and put the tial BOV on. problem though. my banjo bolt for the oil feed line is leaking oil. is there something special that i need to do.
they are brand new though could i try lock washers.
Do you have one copper washer on each side of the banjo bolt? You need both. Also, no, a lockwasher will not work because it will not seal the banjo bolt at all. What did you torque the banjo bolt to?
yes i had 2 copper crush washers. doesn't matter now b.c i just broke the bolt in half trying to tighten it to seal. does anyone have any idea why the crush washers didn't seal, or was i just unlucky
so was i just unlucky or what. was i doing somthing wrong???? :rolleyes:
Status
