ivanr4g63
- 1,021
- 12
- Jan 11, 2003
Linden/Front Royal,
Virginia
My motor is 168k bone stock, well except for the head rebuild like 26k miles ago, I need piston rings really bad, the car runs fine at driving speeds, but as soon as I step on the gas and build boost smokes the hell out of the whole neighborhood, although its crazy because I do compression tests often and compression has never gone any lower than 150 psi, but the leak down test comfirmed piston rings... The thing is that beeing that motor is high mileage I checked crank and rod bearings and they seem in rather good shape, so Im replacing main and rod bearings and piston rings,
But can I do this all in standard size?
I guess I would love to go to a propper bore size, but im really on a tight budget, plus I cant have the car down for long...any input is gladly apreciated.
oh well i need the money
wtf
